| Product(s): | InRoads | ||
| Area: | Geometry | ||
| Subarea: | |||
| Original Author: | Jacquelyn Pettus, Bentley Technical Support Group | ||
Where is the Reverse Transition command located?
The Reverse Transition command is located in the Civil Geometry section of the Tasks bar. To access all the different options for creating a reverse curve, left click on the icon and hold it for a split second and a menu will appear with several options to create reverse curves.
The Tasks bar can be open from within Microstation by toggling on Tools > Tasks.
