| Product(s): | InRoads | ||
| Version(s): | 08.11.09.493 | ||
| Area: | Surface | ||
| Subarea: | |||
| Original Author: | Sanders Thomas, Bentley Technical Support Group | ||
Problem:
I have 2D towers that I need to be able to identify the elevations.
The most efficient method is to use the Drape Surface command. Surface>Design Surface>Drape Surface allows the user to project graphics (towers) to a specific surface applying the surface elevation to the graphics.
