| Product(s): | InRoads | ||
| Version(s): | 08.07.00.65+ | ||
| Area: | Reports | ||
| Subarea: | |||
| Original Author: | Jacquelyn Pettus, Bentley Technical Support Group | ||
In the previous versions on Inroads I was able to load a DBA file to run reports. Is this still possible in SELECTseries 2?
Beginning in version 8.7, the DBA files were replaced with XML Reports. You can access the XML Reports in Tools > XML Reports. For more information regarding XML Reports, please visit the Reports Section of the Road and Site Design wiki.
