| | Applies To | | |
| | Product(s): | InRoads | |
| | Version(s): | 08.11.07.615 | |
| | Environment: | N/A | |
| | Area: | File | |
| | Subarea: | | |
| | Original Author: | Jacquelyn Pettus, Bentley Technical Support Group | |
Question:
How can I open an ALG in a previous version of InRoads?
Answer:
The following workflow will allow ALG files to be saved down to a previous version of InRoads:
- Open the ALG in the current InRoads version.
- Select File > Save As.
- Change the Save as type to "Geometry Projects (*.alg)". Click the Options button.
- The Geometry Options dialog lists the formats that are available when saving a geometry project. Select the version that you would like to save down to and select OK.
