| Product(s): | InRoads Suite | ||
| Area: | Tools | ||
| Subarea: | |||
| Original Author: | Jacquelyn Pettus, Bentley Technical Support Group | ||
How do I export cross section data to HEC-RAS, HEC-2, or WSPRO?
The Generate Water Surface Data command provides this functionality.
You will first need to enable the Hydrology and Hydraulics add-in. To do so, go to Tools > Application Add-Ins and toggle on "Hydrology and Hydraulics Add-in". The Generate Water Surface Data command can then be accessed in Evaluation > Hydrology and Hydraulics > Generate Water Surface Data.
The Cross Sections Tab allows you to define the parameters for the cross sections. The cross sections are defined using linestrings in the graphics file and are identified using a selection set, by level, or by alignment. For additional information regarding the command, select the Help button on the dialog box.
