| Product(s): | InRoads | ||
| Area: | Surface | ||
| Subarea: | |||
| Original Author: | sanders thomas, Bentley Technical Support Group | ||
I get an error message when trying to triangulate a surface.I receive and error massage but can't find anything wrong at the location called out.
"Triangulate Surface Command Report Triangulation halted. Untriangulatable data found at …. Check point data in this area for errors."
This issue has been seen before and Surface>Triangulate Surface and select Extended Data Check and then Apply usually corrects this issue. If that doesn’t work, another solution found is Surface>Utilities>Resolve Crossing Segments.
