| Product(s): | InRoads | ||
| Area: | Reports | ||
| Subarea: | |||
| Original Author: | Sanders Thomas, Bentley Technical Support Group | ||
This report is ListCoordinates.xsl with Description added for Cogo Points.
Unzip the file Radial Stakeout Report.zip and place in the XML Data directory. This report should be placed in the Stakeout folder.
(ex for V8i SS2 - C:\Program Files (x86)\Bentley\InRoadsGroup V8.11\XML Data\en\Stakeout)
