| Product(s): | InRoads | ||
| Area: | Reports | ||
| Subarea: | |||
| Original Author: | Jacquelyn Pettus, Bentley Technical Support Group | ||
What is the difference between a station-base and a station-offset report?
In both cases, the offset (distance) is measured from the base alignment/feature to the offset alignment/feature. It is the stationing measurement that differs. In a station-base report, stationing is measured along the base alignment. In a station-offset report, stationing is measured along the offset alignment.
