| Product(s): | InRoads | ||
| Area: | Surface | ||
| Subarea: | |||
| Original Author: | Jacquelyn Pettus, Bentley Technical Support Group | ||
Status Not Changed
When attempting to use Set Elevation command on an element, receiving a "status not changed" error message.
The Set Elevation command can only be used with with lines, polylines/linestrings, and arcs. It will not work with b-spline elements. The b-spline can be converted to a line, linestring or arc using microstation Tools > Curves > Curve Utilities > Facet Curve command.
