| Product(s): | InRoads Survey | ||
| Version(s): | 08.11.07.246 | ||
| Area: | Survey | ||
| Subarea: | |||
| Original Author: | Chris Key, Bentley Technical Support Group | ||
Failed to Import
I cannot import files into InRoads Survey. When I try going to File > Import > Survey Data and try to import a CSV, XYZ or tab delimited file I get an error message that the import failed.
When importing survey data, there are different Text Import Wizards that are used to import the information based on the 'Files of Type' option you specify for the import. When importing the text files, change the Files of Type to "Text File(*.*)" and you can import the file without the error message appearing.
