| Product(s): | InRoads | ||
| Version(s): | 08.11.07.428 | ||
| Area: | Surface | ||
| Subarea: | |||
| Original Author: | Sanders Thomas, Bentley Technical Support Group | ||
Is it possible to create triangles between stations? Because of the size of the DTM, the processing time is extremely long.
The most effective method to display triangles within station limits is to fence the desired area and select Fence Mode (Inside) within the View Triangles command.
