| Product(s): | InRoads | ||
| Area: | Geometry | ||
| Subarea: | |||
| Original Author: | Jacquelyn Pettus, Bentley Technical Support Group | ||
I am attempting to create COGO points, however, the COGO point is not being created at the location I select. It seems to be snapping to some other location.
The most likely solution is that you need to disable the Point Snap Lock.
The Point Snap lock enables or disables your ability to snap or lock onto any point contained in the geometry project. Use this lock to aid the placement process of geometry elements. For example, if you want to input point data into a dialog box, you can toggle this lock on and place a data point in the drawing file. The software finds the closest point and displays the point data in the dialog box.
