| Product(s): | InRoads Storm & Sanitary | ||
| Area: | Drainage | ||
| Subarea: | |||
| Original Author: | Jacquelyn Pettus, Bentley Technical Support Group | ||
I understand that InRoads Storm & Sanitary has the ability to import/export data from/to Micro Drainage, but I cannot find the commands. Where are those tools located?
The Micro Drainage commands allow you to do the following:
To display the Micro Drainage commands, do the following:
Click Tools > Drainage > Menus.
Click the Micro Drainage check box to toggle it on (a check mark appears in the box).
Click Apply.
The Micro Drainage commands can now be found at:
File > Import > Micro Drainage
File > Export > Micro Drainage
Drainage > Flows > Create Super Area
