| Product(s): | Bentley MXROAD | ||
| Version(s): | 08.11.07.566,08.11.09.494 | ||
| Area: | Drainage Design | ||
| Subarea: | N/A | ||
| Original Author: | Jason Walsh, Bentley Technical Support Group | ||
With more companies using Bentley Navigator it is important for users to be able to bring their project data (i.e. MX Drainage Design) into the software. As well as the CAD element data users also require to be able to interrogate the intelligence (meta data) behind the elements.
The steps below explain the process of how to do this with an MX Drainage Design.
