| Product(s): | InRoads | ||
| Area: | Survey | ||
| Subarea: | |||
| Original Author: | Sanders Thomas, Bentley Technical Support Group | ||
How can a user export cross sections in a format that can be directly imported into Trimble data collectors
for staking?
The Upload Trimble Translator will allow a user to export data that can be imported into Trimble data collectors. To do so, select Tools>Application Add-Ins>Upload Trimble Add-In, this will add the Upload Trimble Translator to File>Translators. Data can then be exported to various formats (Geometry, Surface and Cross Sections) and can then be uploaded into Trimble instruments.
