| | Applies To | | |
| | Product(s): | Bentley MXROAD | |
| | Version(s): | 08.11.09.493 | |
| | Environment: | N/A | |
| | Area: | Settings | |
| | Subarea: | Color Table | |
| | Original Author: | Jason Walsh, Bentley Technical Support Group | |
The active Color Table attached to the DGN controls how the DGN is displayed. In MX v8i Select Series 3 the Seed files for the OpenRoads design generally have the Microstation Color Table attached. Users may require the use of a different color table for thier design.
- Select Settings -> Color Table
- Select File -> Open from the Color Table panel.
- Open the file color table you require. Click OK. The main color table are located as detailed below.
C:\ProgramData\Bentley\MX V8i (SELECTseries 3)\WorkSpace\System\data\mosscolours.tbl
C:\ProgramData\Bentley\MX V8i (SELECTseries 3)\WorkSpace\System\data\acadcolor.tbl - Click Attach.
MX Support Clips, TechNotes & FAQs
OpenRoads Support Clips, TechNotes & FAQs
