| Product(s): | InRoads | ||
| Area: | Drainage | ||
| Subarea: | |||
| Original Author: | Jacquelyn Pettus, Bentley Technical Support Group | ||
How do I specify the starting station for a drainage profile?
In the Create Profile dialog, navigate to the Source leaf. If you select "Network" as the Drainage Network Reference, you will be able to specify the starting station of the profile, beginning at the first structure you select:
