| Product(s): | InRoads | ||
| Area: | Drainage | ||
| Subarea: | |||
| Original Author: | Jacquelyn Pettus, Bentley Technical Support Group | ||
How do you annotate the width of circular pipes using Annotate Drainage Profile command?
The diameter of circular pipes should be input as HEIGHT not WIDTH in order for them to be annotated properly.
