| Product(s): | InRoads | ||
| Area: | Startup | ||
| Subarea: | |||
| Original Author: | Jacquelyn Pettus, Bentley Technical Support Group | ||
When a DGN file is double-clicked to open it from Windows Explorer, the Applications menu item does not appear. How can I make sure the Application menu is available when opening the file by clicking in Windows Explorer??
If you want to be able to open a DGN from Windows Explorer and have the applications menu visible, you should create a text file with the name "LoadInRoads.cfg". It should contain the text "Load_InRoads_SS2=1". Place this file in the following directory depending on your operating system. If you have installed InRoads in a location other than the default directory, you will need to install the file in that path.
64bit machine - C:\Program Files (x86)\Bentley\MicroStation V8i (SELECTseries)\MicroStation\config\system
32 bit machine - C:\Program Files\Bentley\MicroStation V8i (SELECTseries)\MicroStation\config\system
