Transfer Data from AutoCad to InRoads
 Product(s):InRoads
 Version(s):08.11.07.615
 Environment: N/A
 Area: File
 Subarea:
Question:
What is the best way to transfer data between AutoCAD and InRoads?
Answer:
LandXML format is currently the best way to transfer data between InRoads and other applications (including AutoCAD).  The following video demonstrates a workflow to import surface/geometry data using LandXML:
Video: Import LandXML Data
