| Product(s): | InRoads | ||
| Version(s): | 08.09.03.06+ | ||
| Area: | Reports | ||
| Subarea: | |||
| Original Author: | Jacquelyn Pettus, Bentley Technical Support Group | ||
This report format is similar to the delivered Minumum Distance report that is delivered with InRoads, however it does the opposite. You must create clearance points for this report by selecting Tools > XML Reports > Clearance. You must include at least one horizontal alignment or feature on the General leaf in the From fields. You must also include at least one horizontal alignment on the Horizontal Alignments leaf or one cogo point on the Cogo Points leaf or one feature on the Features leaf.
Unzip the file Maximum Clearance Report Format and place it in the XML Data directory for the version of the product installed. This report may be placed in the Custom folder or the Geometry folder.
(ex for XM - C:\Program Files\Bentley\InRoads Group V8.9\XML Data\Custom)
(ex for V8i SS2 - C:\Program Files (x86)\Bentley\InRoads Group V8.11\XML Data\en\Custom)
