| Product(s): | InRoads | ||
| Area: | Drafting | ||
| Subarea: | |||
| Original Author: | Jacquelyn Pettus, Bentley Technical Support Group | ||
I have a horizontal alignment with a station equation. When using drafting notes, I would like to omit the station equation name. Is this possible?
If you click on Settings in drafting notes, that will bring up the Settings dialog. There is an option there to "Drop Equation Name". This option displays the station value of stations without displaying the station equation name. For example, when on, station a10+00.00 would be formatted as 10+00.00. When off, station a10+00.00 would be forrmatted as a10+00.00.
