| Product(s): | InRoads | ||
| Area: | ProjectWise Integration | ||
| Subarea: | |||
| Original Author: | Jacquelyn Pettus, Bentley Technical Support Group | ||
Where can I find more information about ProjectWise Intergration with InRoads/RailTrack?
Bentley delivers a document with the InRoads product line that is useful when setting up ProjectWise Integration. To access this document go to Help > Contents in the InRoads Explorer. Navigate to Supplemental Information > ProjectWise and you will find an Overview on ProjectWise Integration. Refer to ProjectWise documentation at docs.bentley.com for more information about installing and using ProjectWise.
