| Product(s): | InRoads | ||
| Area: | Roadway Designer | ||
| Subarea: | |||
| Original Author: | Jacquelyn Pettus, Bentley Technical Support Group | ||
When I create a new surface in Roadway Designer, no feature is created for one of the points in my template.
Check to see if this point is a null point (meaning that it is not a member of any component). If it is, make sure that "Include Null Point" is toggled on in the Create Surface dialog.
