| Product(s): | InRoads | ||
| Area: | Geometry | ||
| Subarea: | |||
| Original Author: | Jacquelyn Pettus, Bentley Technical Support Group | ||
The Design Calculator on the Define Vertical Curve Set dialog is grayed out and not available.
The Design Calc button is disabled in the following products: Storm & Sanitary, Bridge, Site, and Survey. Furthermore, the Design Calc button is available only when the Curve Definition for the active vertical alignment is
Parabolic. The Design Calculators dialog box is not available when the Curve Definition is set to Circular.
