| Product(s): | InRoads | ||
| Area: | Profiles | ||
| Subarea: | |||
| Original Author: | Sanders Thomas, Bentley Technical Support Group | ||
Is it possible to display the vertical alignments from profiles onto another profile? This would be helpful in
preliminary design.
The vertical alignments from one profile can be displayed in another profile by using the Alignment to Profile command. This will allow a user to display multiple preliminary design alignments.
