| Product(s): | InRoads | ||
| Area: | Geometry | ||
| Subarea: | |||
| Original Author: | Jacquelyn Pettus, Bentley Technical Support Group | ||
I am trying to use the command Geometry > Horizontal Curve Set > Add PI to place multiple PIs. However, I can only place the first two and unable to place a third PI.
This problem most commonly occurs when the user has unintentionally toggled on Design Criteria. Try turning off Design Criteria by going to Geometry > Horizontal Curve Set > Design Criteria.
