| Product(s): | InRoads | ||
| Area: | Surface | ||
| Subarea: | |||
| Original Author: | Jacquelyn Pettus, Bentley Technical Support Group | ||
Which surface file formats does Data Acquistion support for import/export?
Using Data Acquisition, the following surface file types can imported:
The following surface file types can be exported:
