| Product(s): | InRoads | ||
| Version(s): | 08.11.09.493 | ||
| Area: | Cross Sections | ||
| Subarea: | |||
| Original Author: | Jacquelyn Pettus, Bentley Technical Support Group | ||
I am trying to create cross sections on a sheet. If the scale is such that the cross sections are too wide to fit on the sheet, I want them to be split and stacked. Instead, I receive the error message "Range of Cross Section...is greater than Sheet Border...'.
If you want the cross sections to be split and stacked when the range is greater than the sheet border, you will need to create custom cross sections.
