| Product(s): | InRoads | ||
| Area: | Surface | ||
| Subarea: | |||
| Original Author: | jacquelyn pettus, Bentley Technical Support Group | ||
How do you remove entries from "Files of Type" In File>Import>Survey Data?
Open the xin file in notepad and manually remove the line(s) with the unwanted file type.
