| Product(s): | InRoads | ||
| Area: | Installation | ||
| Subarea: | |||
| Original Author: | jacquelyn pettus, Bentley Technical Support Group | ||
How do you uninstall the 08.11.07.566 update?
The update alone cannot be uninstalled. Instead, the full build (08.11.07.536) must be uninstalled, which will also uninstall the update.
