| Product(s): | InRoads | ||
| Version(s): | 08.11.09.493 | ||
| Area: | Drafting | ||
| Subarea: | |||
| Original Author: | jacquelyn pettus, Bentley Technical Support Group | ||
How do you set Window Clearance parameters in Plan and Profile Generator?
The Profile Preference option on the Profile Controls Tab in Plan and Profile Generator specifies a preference set that was saved in the Create Profile command. By specifying a preference from the Create Profile command, you can reuse, rather than redefine, various settings that control the appearance of the profile. The Window Clearance parameters are one of the settings that can be loaded using this option.
