| Product(s): | InRoads | ||
| Area: | Installation | ||
| Subarea: | |||
| Original Author: | Sanders Thomas, Bentley Technical Support Group | ||
Does InRoads V8i SELECT Series 2 run on the AECOsim build of MicroStation?
No, InRoads is not certified to run on the AECOsim build of MicroStation. This is true for InRoads SELECT Series 2 and SELECT Series 3 both will fail. Nor is there a workaround that will allow the user to launch InRoads inside this platform.
