| Product(s): | Bentley Rail Track | ||
| Version(s): | 08.11.07.566 | ||
| Area: | Reports | ||
| Subarea: | |||
| Original Author: | Sanders Thomas, Bentley Technical Support Group | ||
What is the recommended method to create a deflection angle report from an alignment?
The recommended method to create a report that returns deflection angles from an alignment is to use the Geometry report. Select Tools>XML Reports>Geometry, select your horizontal alignment and then Apply. Next, select Geometry>TransversePoints.xsl.
