| Product(s): | InRoads | ||
| Area: | Geometry | ||
| Subarea: | |||
| Original Author: | Sanders Thomas, Bentley Technical Support Group | ||
Create/Edit Alignment by CogoPoints does not populate points beginning with Alpha characters. How can this be corrected?
Select Tools > Variable Manager. There is a variable under Command Behavior - Geometry - "Alphanumeric names in Create/Edit Alignment by Cogo Points". This variable permits the command to populate points with Alpha characters.
