| | Applies To | | |
| | Product(s): | InRoads | |
| | Version(s): | 08.11.07.615 | |
| | Environment: | N/A | |
| | Area: | ProjectWise Integration | |
| | Subarea: | | |
| | Original Author: | Jacquelyn Pettus, Bentley Technical Support Group | |
Question:
In Projectwise, how do you associate a dgn with InRoads?
Answer:
In addition to setting up the association to the file, you also need to enable legacy integration. To do this, use the following steps:
In ProjectWise Explorer:
- Open the Program Associations dialog (Tools > Associations > Programs).
- Set the Association view to User associations.
- In the Applications list, expand the InRoads application.
- Expand the “Open” action.
- If the action does not yet have a program associated to it, associate it with InRoads.
- Expand the program so that the options Command Line Arguments, Enable Legacy Integration, and Replace Default Arguments display.
- Right-click Enable Legacy Integration and choose Enable Legacy Integration.
- Now right click on the dgn, go to properties, and associate it with InRoads.
- Click save and the file will open with InRoads.
