| Product(s): | InRoads | ||
| Area: | General | ||
| Subarea: | |||
| Original Author: | Jacquelyn Pettus, Bentley Technical Support Group | ||
How do I assign a function key in to open InRoads in MicroStation?
To assign a Function Key to open InRoads, please follow these steps:
Please note that these are the default locations of the ma, if you have installed InRoads in a different directory, you will need to use that path to the ma – just search for “civustat.ma”. Also, you need the quotation marks in the command line for it to load.
