| Product(s): | InRoads | ||
| Area: | Volumes | ||
| Subarea: | |||
| Original Author: | Jacquelyn Pettus, Bentley Technical Support Group | ||
How can I determine the volume between a DTM file and a GSF file?
The GSF (Site Modeler) file will need to be converted to a DTM first using Site Modeler > Site Tools > Create Surface. Then the cut/fill volumes between the two DTMs can be determined using Evaluation > Volumes > Triangle Volumes.
