| Product(s): | InRoads | ||
| Area: | Survey | ||
| Subarea: | |||
| Original Author: | Jacquelyn Pettus, Bentley Technical Support Group | ||
Build extended descriptions does not work in the Survey Data to Geometry command.
There must be an attribute associated with the feature code in order for the extended description function to work in the Survey Data to Geometry command.
