| Product(s): | InRoads | ||
| Version(s): | 08.11.07.615+ | ||
| Area: | Roadway Designer | ||
| Subarea: | |||
| Original Author: | Jacquelyn Pettus, Bentley Technical Support Group | ||
What is the difference between Template Origin and Dynamic Origin in Create Template?
The Dynamic Origin is indicated by the purple box and is used as the reference for the step lock values, and OL= and OS= key-ins on the Dynamic Settings dialog. This option is accessed with a right-click during an add or edit process.
The Template Origin is used to set the location of the origin of the template. This option is accessed with a right-click during an edit process. When this command is executed, the entire template is shifted so the selected point is at the origin (0,0).
