| Product(s): | InRoads | ||
| Area: | Cross Sections | ||
| Subarea: | |||
| Original Author: | Jacquelyn Pettus, Bentley Technical Support Group | ||
How are End Area Volumes calculated in InRoads?
The End Area Volumes calculation is based on the traditional end-area volume calculation to compute cut, fill, and net volumes using a series of cross sections along a previously defined alignment:
Using this method, two end areas are averaged over the entire length between them:
Where:
This method is the least accurate of all the volume calculations, however it is widely accepted by engineers/contractors. Furthermore, the accuracy of the end area calculation is indirectly proportional to the cross section interval.
