| Product(s): | InRoads | ||
| Area: | Drafting | ||
| Subarea: | |||
| Original Author: | Sanders Thomas, Bentley Technical Support Group | ||
When I use the command Plan and profile Generator, the command creates a few profile views from the main profile. I will annotate it with annotate profile, I check on the Cumulative Station and every profile starts with 0.00 (not cumulative station); but I need the stationing to from the last profile (cumulative). How can I correct this?
This can be corrected by the user selecting Profile>Annotate Profile>Selection>Stationing versus Cumulative Stationing; this will allow the user to receive their desired results.
