| Product(s): | InRoads | ||
| Area: | General | ||
| Subarea: | |||
| Original Author: | Sanders Thomas, Bentley Technical Support Group | ||
Prior to transitioning to Power InRoads we need to continue using our InRoads license (08.11.07.615) on AutoCAD (2012). We are buying the user a new computer and need to confirm that InRoads will run in a Windows 7 32-bit operating system (we are aware it will not run in a 64-bit operating system environment).
InRoads version 08.11.07.615 is certified to run on the platform AutoCAD 2012, 32 bit. This is also documented for your confirmation in the Readme file delivered with the software and located at C:\Program Files (x86)\Bentley\InRoads Group V8.11.
