| Product(s): | InRoads | ||
| Version(s): | 08.11.07.566 | ||
| Area: | Surface | ||
| Subarea: | |||
| Original Author: | Jacquelyn Pettus, Bentley Technical Support Group | ||
The following video will demonstrate the use of the command Generate Inferred Breaklines to resolve issues with jagged contours.
This workflow resolves the typical issue where contours are provided in a DGN from an external source, then after importing the graphics into InRoads, the contours from the Surface>View Surface>Contours command do not match the original graphics.
Click the video below to play it. To view in fullscreen mode, first click the YouTube link at the bottom of the video to launch the video on the YouTube site. Then, click the fullscreen button (rightmost button at bottom of video).
Recorded in 1024 x 768 resolution.
