Applies To | |||
Product(s): | InRoads | ||
Version(s): | 08.11.07.615 | ||
Environment: | N/A | ||
Area: | Drainage | ||
Subarea: | |||
Original Author: | Sanders Thomas, Bentley Technical Support Group | ||
The HGL graphics in drainage profiles are not continuous; they appear as a single dash. What could possibly cause this behavior?
This is usually caused by corruption in HGL up and HGL down values. Select Edit/Review Pipe>HGL/EGL pipe, correct the HGL up and HGL down and then run Network Design again.
