| Product(s): | InRoads | ||
| Area: | Geometry | ||
| Subarea: | |||
| Original Author: | Jacquelyn Pettus, Bentley Technical Support Group | ||
How can I change which element is defined as the POB of an alignment?
Use the Check Integrity tool to reorder the horizontal alignment elements.
