Draw XS from Surfaces won't find Patterns
 Product(s):Bentley GEOPAK Road
 Version(s):08.11.09.674
 Environment: N/A
 Area:
 Subarea: N/A
 Original Author:Nico Roman, Bentley Technical Support Group
Error or Warning Message
The error states could not find patterns with the specified criteria.
Explanation
Most likely, the patterns specified in the draw xs from surfaces tool cannot be found.
How to Avoid
Go to the dgn where the pattern lines are, do a match to select the attributes of the element. Make sure the tool can display/undisplay the selection.
Also, make sure the patterns are either Microstation lines or line-strings. The tool will not work with complex chains.
