| Product(s): | ProjectWise Dynamic Composition Server (DCS) | ||
| Version(s): | 08.11.11.xx | ||
| Area: | |||
| Subarea: | |||
| Original Author: | Dawn Gentry, Bentley Technical Support Group | ||
Getting error when submitting a rendition from ProjectWise Explorer: “Error Code 100”
You may get this error if an attribute has been deleted from a ProjectWise Environment that may be currently defined in the “Output Destination Folders” profile component’s attribute mapping for the job you are running.
You can solve the problem by opening the output destination folder profile component and open the attribute mapping dialog. The dialog will automatically fix the mapping by removing it. Select OK to save the attribute mapping and component. The error should be cleared.
