| Product(s): | ProjectWise Dynamic Composition Server (DCS) | ||
| Version(s): | 08.11.11.xx | ||
| Area: | |||
| Subarea: | |||
| Original Author: | Dawn Gentry, Bentley Technical Support Group | ||
Getting error: “Failed to create plot set: ProjectWise Error - PWISE, ProjectWise API Error: Error setting a user parameter. ProjectWise API Error Detail: Invalid argument passed to dmsapi function.” Or Failed to create plot set: ProjectWise Error - PWISE, ProjectWise API Error: ProjectWise API Error Detail:”
Make sure you login once as the special “dcs user” to create the pw local working folder.
