| Product(s): | ProjectWise Dynamic Composition Server (DCS) | ||
| Version(s): | 08.11.11.xx | ||
| Area: | |||
| Subarea: | |||
| Original Author: | Dawn Gentry, Bentley Technical Support Group | ||
When editing or running an automated job in DCS, the following error occurs:
Job definition can not be edited due to ProjectWise login failure. Could not log in to datasource "PW.bentley.com:PW" as user "DCSUSER". Cannot login to the datasource. Detail: Your ProjectWise login session has expired. Please log in again. ProjectWise error ID 58243.
Right click on the job and select “Change credentials”. Retype the username and password.
